TwinTurbo.NET: Nissan 300ZX forum - I'd just do a meter continuity check between the ECU
Subject I'd just do a meter continuity check between the ECU
Posted by jzack on May 08, 2008 at 6:14 PM
  This message has been viewed 179 times.
In Reply To Is it possible you've got a pinched/cut wire from doing posted by Dave N on May 08, 2008 at 10:20 AM
Message pins and the O2 connector. Should be easy to tell if the ECU pinout is right or the harness or connector has a connection issue on one of the lines???
